My Replace Lamp light just started coming on when I turn on my projector. I am currently at 1,807 hours and according to the manual the bulb will most likely burn out at or about the 2,000 hour mark. My question is where is a good place or site rather to get the replacement bulb? I did a quick search on ebay but the prices are so low I don't want to end up with a cheap knock off because I fell for the low price. I did find one on a site just under $200 and they claim its a OEM replacement bulb and it comes with the housing as well. Before I choose that particular company I wanted to check in with you all to see if I should look at some other sites...I need to have the bulb replaced before this weekend.
