Status
Not open for further replies.
1 - 4 of 4 Posts
Banned
I need your help/input. After reading the Fujitsu thread about DVI connections and native rate, I would like to know if anyone has had any success USING DVI and running native rate of 1366 x 768 into either the Panasonic and/or the NEC.
If so, I could really use a link to the user manual where it states that it can accept it or and email or fax would be MOSt helpful. Please help out a new guy. Thanks
Brad
Not sure which 50†NEC model you are looking to buy but here are links to a number of models.
The 50MP1 is discontinued, user’s manual found at :
http://www.necvisualsystems.com/corp...new_040201.pdf
The 50PD1, also discontinued, manual at :
http://www.necvisualsystems.com/corp...2PD2_50PD1.pdf
The 50PD2, discontinued, manual :
http://www.necvisualsystems.com/corp...N_50PD2_v1.pdf
The 50MP2 is not yet discontinued and it’s manual is here :
http://www.necvisualsystems.com/corp...N_50MP2_v1.pdf
These manuals probably hold the information you seek.
Regarding info on Panasonic, I am of no help.
this is what NEC tech support told me about the NEC MP1 61
Question:
I am trying to achieve 1365x768 input resolution from an external Focus
Enhancement CenterStage CS-2 line scaler. Right now the line scaler is
set to scale to 1366x768 but the NEC plasma states the resolution is
1024x768 under the Information display. My input is VGA cable. Will a
DVI cable make a difference or do you think the line scaler is not sending
the proper resolution ?
Response:
The plasma may be "thinking" that the signal input's resolution is 1024 x
768 instead of 1366 x 768 due to the signal timings &/or polarity. When youare sending the plasma the 1366 x 768 signal from your scaler, what does the plasma report for the Horizontal & Vertical signal timings & polarity?
1 - 4 of 4 Posts
Status
