1 - 9 of 9 Posts
PL mount is a showstopper for me.
Here are the main specs of the camera:
4096 x 2160 Super 35mm CMOS sensor
14+ Stops of Dynamic Range
PL Mount
Internal 4K up to 120fps
Records 4K & UHD in AVC-ULTRA 4K
Records 2K & HD in AVC-Intra 100/200
Capable of 4K RAW
1.5 to 6 Mbps Proxies
Two expressP2 card slots (Record 130 minutes of 4K/24p with these cards)
Two microP2 card slots (for HD and 2K)
Four 3G-HD-SDI Outputs for 4K QUAD
Two 3G-HD-SDI Outputs for RAW
HD-SDI out for monitoring (down-converting from 4K)
Two XLR inputs can record four channels of 24-bit, 48KHz audio
Removable Control Panel
OLED Viewfinder with Optical Zoom
Availability: Fall 2014
Price: TBA
http://nofilmschool.com/2014/02/panasonic-varicam-super-35-4k-raw-120fps-varicam-hs-2-3-inch-1080p-240fps/
Micro 43rds lenses would Vignette on an S35 chip camera. The camera would need a crop mode. Anyway, people who'll be able to afford a camera like this will also be able to afford good PL mount lenses.
I definitely wouldn't mind recording 4K footage at 120 frames a second.
Originally Posted by Paulo Teixeira  /t/1520328/panasonic-announces-the-next-4k-camcorder-but-with-pl-mount#post_24423091
Very true. PL is the industry standard for cinematographers. This is not a hobby camera. It really should have 96Khz audio these days.
Here's some better images of this.
1 - 9 of 9 Posts
