I was wondering if anyone has replaced the ballast on this set themselves and how hard it was. My set is giving me the "replace bulb" message after about 12k hours. I purchased and replaced the bulb (Osram OEM from River Valley Electronics via Amazon)but it would not light. I sent the bulb back to River Valley and they are going to test it to make sure it is not the bulb. If they test the bulb and it lights, then the tech told me it is likely the ballast. I can purchase the ballast/board from Panasonic (part# EUBMM021A10) for $222.17
Secondly, I was wondering if there was also a resource to view the different components internally (fans, etc)from a technical perspective. Something that maybe has pictures with the different components labeled?
Thank you in advance to all that respond.
