Status
Not open for further replies.
1 - 2 of 2 Posts
Panasonic DMP-BD80 ???'s (help)
Is there way to stream wireless with this player - I have it running with LAN connectors from my router to the back of my player however for some reason because all my devices are connected to one circuit when I go to stream it's popping my breaker.
Can't move the location of the units as they located in built in bookcases. Rather then go through the expense of an electrician I thought this would be a better less expensive choice.???
1 - 2 of 2 Posts
Status
