I just purchased this unit to archive shows from my DirecTIVO to DVD-R. My existing setup has been working fine using the audio-video cable from the DTIVO into my receiver and then the video output of the receiver to my TV.
So to make as few changes as possible I thought that I would take the coax output from my DTIVO which is not currently in use (and has the same signal as the audio-video cable output) and use that as the input signal on the E80. Then take the coax output on the E80 and attach that to the coax input on my TV. During normal viewing I would select the audio-video cable input on the TV and when creating a DVD recording I would select the coax cable input on the TV.
Well the DTIVO video signal definitely makes it through the E80 and to the TV. What I can't do is get any of the E80 functions to display on the TV through the coax connection. I then tried connecting the E80 to my TV with an audio-video cable and everything works fine. I have already started recording data to the HDD for editting and transfer to DVD-R. The problem is that I have to move the original video cable from my receiver back to the TV when I'm not using the E80 :-( It's no so easy reaching behind the TV.
After a long explanation, basically I just want to confirm if I should be able to use the coax output of the E80 as I originally was trying to configure ?
Thanks for you help.
