I had a strange problem occur on my Panasonic DMR-E85H.
A few days ago I set a program to record(1 hour) on the DMR-E85H's HDD and only approximately 7 minutes recorded.
Today I had the timer set to record an hour long program and basically the same problem happened again. Only 32 minutes recorded and it paused a few times during playback. I was able to fast forward past the paused section and get it to play again.
I tried deleting the bad recording from the HDD and I got a message saying 'Invalid In Recording' and was not able to delete it. I also couldn't shut the recorder off. It was basically frozen.
I had to unplug it and when I plugged it back in it immediately went into 'Self Check' mode. After it ran the Self Check mode it seems OK.
I have the recorder hooked up to a Verizon FIOS cable box. I also have a Panasonic DMR-E100H, also hooked up to a Verizon FIOS cable box and have never had this problem occur.
Has anyone experienced this with one of the Panasonic HDD recorders?
