1 - 3 of 3 Posts
Discussion Starter #1
My dad owns a Panasonic DMR-EZ27 dvd recorder. He tried to record a television show, but once it was finalizing the disk, there was an error. The disk will not eject. It displays several 0's on the LED screen. The dvd wont even play, you can hear the audio for a few seconds before it displays the error.
We've tried:
Holding down eject and pause
Unpluging it then plugging it back in (3 times)
Clicking eject
Calling panasonic (they wont pick up!)
Etc.
Please let me know if you have any idea about what we should do!
You could try holding down both the CH up and CH down for ten seconds, which should do a factory default reset. But if your Panny is like several of mine, it won't help. I had 3 units die with U99, and none would let me eject the disc. After the reset the unit would try and read the disc, then get U99. I could not stop the unit from trying to read the disc, otherwise if I could have ejected the disc, I think it might have been OK. I ended up exchanging all units, I'm thinking you may need to do the same. Good luck!
1 - 3 of 3 Posts
