Status
Not open for further replies.
1 - 2 of 2 Posts
I've recently discovered and adjusted the audio settings on my Panasonic DMR-E50 to output in DTS by altering the settings to bitstream, as I have the DMR-E50 connected to a Sony home theatre unit which is DTS compatible.
I've got a question regarding the audio settings:
I don't always put the Home Theatre kit on and just listen through the TV speakers (via SCART). The manual warns about sending DTS signals to equipment that isn't DTS compliant. Is DTS only output through the optical connection or should I reset the Panny settings to the non-DTS settings when listening through the telly.
And also, what effect if any does this have on recording programs on the Panny and then playing back ?
Cheers
Neal
1 - 2 of 2 Posts
Status
