Basically. what I have is a Toshiba 15" diagonal LCD TV/DVD combination (model 15dlv76) connected to a Panasonic DVD recorder model dmr-ez28. When setting everything up, I noticed the DVD recorder works. But, I am not getting the setup menu. I have yellow socket connected to y-in to the Toshiba and the other end of the yellow connected to the video-in terminal of the Panasonic DVD recorder. I have the white socket connected to pb white terminal to audio inl l of the Panasonic DVD recorder. Finally, I have the red socket plugged into pr of the Toshiba and the other end plugged into the audio in of the to the Panasonic DVD recorder. One coaxial cable, connected from Radio shack hd antenna to RF in on DVD recorder unit. Finally, I have another 75 ohm coaxial cable connected from rf out on the DVD recorder connected to the vhf/uhf rf in the Toshiba. But, the problem is the dvd recorder is working. The clock blinks. The cd holder works. The only problem is I cannot get get the setup menu. Oh, is there any way I can get even better reception. It is hard to do w/ such a 420p tv. thanks.
