What speed did you originally record the movie in? If you recorded in SP mode, you should be able to High Speed dub it without having to re-encode down to a different record mode.
Originally posted by skfields01 So if I record the 2:10 Laserdisc onto the HDD in SP... then I should be able the use High-Speed dub and that will not re-encode the DVD? |
Usually I use XP to the HDD for the best quality from the original source. Isn't SP a lower quality? Then I wonder what way will look best... |
Going to the HDD in SP (Lower quality) and then dubbing in High-Speed with no re-encode... or Going to the HDD in XP (Higher quality) and then dubbing in SP/FR which then re-encodes the DVD? |
TonyRz... 2:10 is too long for SP... or so it says. |
Originally posted by skfields01 TonyRz... 2:10 is too long for SP... or so it says. |
