1 - 4 of 4 Posts
For the first time in several years I tried to use the USB port to play a movie I have on a portable USB drive. I cannot find a way to select the USB port. It is not listed on the Drop down menu using the Inputs button on the remote. I tried the Viera Media Player and it doesn't seem to be listed there either.
What am I missing or how do I select the USB port?
Thanks very much,
Bill
If your drive is Hard Drive based the tv won't have enough power to run it. You need a flash drive or a powered external 2GB or smaller. I'm pretty sure mkv and avi aren't compatible. The USB ports will only show up in the tv's media player.
Discussion Starter · #4 ·
Thanks for the responses. The drive in question is a flash drive, I don't know the file format but this video played on a friend's Samsung. I will try the viera Connect process and see if that works.
1 - 4 of 4 Posts
