Status
Not open for further replies.
1 - 2 of 2 Posts
I have a Panasonic PT-51G50U RPTV (about 6 years old) that is experiencing the following problem:
Every once in a while (frequency of occurrence is increasing), the unit just shuts off by itself. In order to get to the point of being able to turn it back on, it must be unplugged and plugged in again. Then, it usually turns off again about a half second after it is turned on. This can go on many tries before it turns on again to the point of getting sound and a picture.
The store I bought from is no longer in business and I'd like to fix as inexpensively as possible, so I'd attempt to do so myself if anyone has any suggestions.
(If it's really screwed up--I'd get to buy a new one!)
Thanks in advance for any help/suggestions.
Jim
1 - 2 of 2 Posts
Status
