1 - 3 of 3 Posts
Does anyone know what the Panasonic Tech Reps are supposed to do/know/help?
My first call on the PT-AE4000 was to find a part number for the trigger jack. They didn't know. I found a post on this forum that it needs a 3.5mm mono jack. Got two at Radio Shack for $2.19. After three days Panasonic finally called me back and said they had the jacks at $20 each.
Just called Panasonic to find out about output voltage. I know it is 12v, but my Da-Lite Cosmopolitan needs 83ma. The screen stays down as long as the jack is providing current.
Panasonic Tech Reps don't have a clue. Suggested an "engineer" would call me back. The screen was working flawlessly with my Optoma WD32.
I have set the trigger to "output" using the info on page 40 of the pdf file on the cd that came with the Panny.
Hoping someone here can help.
Discussion Starter · #2 ·
Anyone have an idea?
Sorry I can't help you but try doing a search in the main Panny thread
using 12v as the searched key word..I'm sure something will pop up as I remember reading about this in that very same thread awhile back and several times at that.
I just never paid any attention to them posts because I don't have that set up.
Goodluck
1 - 3 of 3 Posts
