1 - 2 of 2 Posts
I have an Panasonic PT-60Lcx64 DLP set. I replaced bulb when powered on it flashes green light for a couple of seconds then flashes temp and lamp red lights a few times then goes to amber light. Took back of set off to check thermal fuse
it has continuity. Then just in case i bypassed the thermal switch still does the same thing any help please.
1 - 2 of 2 Posts
