Status
Not open for further replies.
1 - 3 of 3 Posts
these units are still available second hand/used
are they as advertised? can you record hdtv with them?
if so, what's the catch if any?
do you have to pair up with the panny STB or can it be used with say the new Zenith STB
All help gratefully accepted
http://www.avsforum.com/ubb/smile.gif
peteg
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
In brief,
Yes, on occasion.
Yes. Yes.
The catch is they are discontinued, and some units can be a little temperamental.
At this time you can only use the Panasonic TU-DST50/51, no other stb will do.
Please check the HDTV Recording Forum, for details.
"better living thru modern expensive electronics"
tm
Discussion Starter · #3 ·
many thanks - sorry posted in wrong forum
peteg
1 - 3 of 3 Posts
Status
