1 - 2 of 2 Posts
I have a Panasonic Viera Cast TV & the FORMAT ( Aspect Ratio ) button is disabled when you are using the Viera Cast mode. When for instance Im viewing a movie from Amazon Prime Video & it does not appear Full screen, the format button is not functional. This is very bad for image retention. Is there possibly a way to enable it or is there a compatible remote out there that I could purchase that would have the capability to format my screen image while Im using the internet connection in Viera Cast. Any ideas I sure would greatly appreciate it! My model # for my TV is TC-P50G10 .
Panasonic only has one such command. So a different remote or code won't help. I haven't seen any reports about the possibility of enabling format in streaming mode. Best you can do is complain to Panasonic (or Amazon) and hope it's changed in a later firmware.
1 - 2 of 2 Posts
