1 - 5 of 5 Posts
Hi just wanted to pass on my results of picture settings on this new television I just picked up. I searched everywhere in this tread regarding this model and found no posted settings
Mode: Cinema
Back light: 52 (middle setting)
Picture: 79
Brightness: 64
Color: 45
Tint: -5
Sharpness: 50
Color Temp: Warm
All other settings: Off
This entry level television from Panasonic packs a lot of punch for the buck. It is a 720p panel
Game mode via HDMI for my PS3 rocks! No Lag....
I used Ratatouille BlueRay that has THX optimizer calibration.
Television is in a small fairly dark room with one small 7 inch flouresent light (picked up at Home Depot) located directly behind the television on the wall with velcro.
hope this helps,
give these settings a try you just might be surprised. Remember each television is a tad different.
I just returned a Westinghouse for this Panasonic the other day at Costco. So far the picture out of the box looks pretty good especially after I changed it to game mode, but I think I'll try out your settings to see if it's better.
Hello guys,
In my menu settings I can find: Picture, Sound, Settings.
As I go into Picture I have this situation:
Mode: Cinema OK
Back light: 52 CAN'T FIND
Picture: 79 CAN'T FIND
Brightness: 64 CAN'T REACH 64 (MAX 30, MIN 30)
Color: 45 OK
Tint: -5 (MIN 0, MAX 10)
Sharpness: 50 CAN'T REACH 50
Color Temp: Warm OK
Why do I have different kind of settings in my TV?
1 - 5 of 5 Posts
