1 - 5 of 5 Posts
I have had this TV a year and a month ago it will power up for maybe 5 seconds, before the pic comes on, then click and shut off leaving the red light at bottom blinking. I can manually press the power button to stop the blinking then press the power to turn it on again. I sometimes get it powered up the first try sometimes it takes 4 0r 5. I see nothing in the manual that addresses this issue. Anyone had similar problems or can help me?
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
Immediately see if you can still get warranty service. The blinking red light and other symptoms mean you have a service problem, probably a bad power supply.
Discussion Starter · #3 ·
I live on Kauai and bought from Sears. do I contact Pana or sears? Not sure if I registered the product or what warranty. Crap
Ken is right although it may not be bad. The blinking red light means the TV has failed the power up routine. Generally it has something to do with the power supply not getting up to speed fast enough. My Panasonic has been doing this for a couple years. Luckly 95% of the time holding down the power button on the unit restores use, the other 5% a second time will work. You might want to check the LCD forum at AVS and search for Panasonic failing power up, you'll find many hits and I think even a dedicated thread on this issue.
My Sony LCD has even done this a couple of times but on it I need to pull the power cord to regain control, it's probably only done this 3 or 4 times though in the last couple years.
Since both my TVs are out of warranty I just live with the occasional inconvenience although it sounds like your problems are more frequent.
Try Sears first, although they will probably refer you to Panasonic.
1 - 5 of 5 Posts
