Hi,
a friend of mine has the combo I posted in the title. I helped him configure it but can't get the correct resolution for everything to work fine. I was able to find a resolution that had pretty much no overscan or underscan but the text does not look crisp. I also tried the standard 720p resolution and that resulted in huge overscan, when I tried 1080p the TV showed nothing, not sure why. The tv is connected with a DVI--->HDMI cable and the latest ATI drivers are installed. The tv's native resolution according to the manual is 1024x768 and I tried that with no luck.
I am looking for people with this particular tv or another Panny that is 720p and is not connected with VGA to help me out with that settings they are using.
BTW I searched and found one thread but it was old and conflicting, some said to use powerstrip and others said to use the resolution tool in ATI control panel, and the thread was old.
Yekshamesh
Yekshamesh
