Hi:
I am on my third TU DST 51. The first two I returned because they simply did not do anything- did not even receive the NTSC channels. I called tech support at Panasonic and I was told to send the units with a deposit of $1200. Instead I took it back to Sears. Tech support also told me that it could be the antennea. No, that was not the problem because my trustworthy DTC 100 was running like a champ and still is with the Winegard antenna.
The reason to have one is obvious. So I went ahead and got another one fron eBay. This one tuned all of the NTSC channels easily. I was encouraged. I then did a channel search for HD channels. WALLA!!! It tuned all the 5 available channels. It worked- or so I thought. When I started to watch the channels they worked but after about 20 minutes, the picture broke up and so did the audio. There were simply lines and heavy pixelization on the screen. I tried again tonight. Same problem. This one works-but partially. I dont know what to do. Can any one of you please advise and help?
