Status
Not open for further replies.
1 - 15 of 15 Posts
Use the following coupon code to get $20 off an order of $200 or more savings to bring it down to $399!
pqexe-16k2y-0jcsk
Just enter the bolded code above during checkout into the “Special Messages†box on the Checkout Form! or just call crutchfield and mention the code over the phone!
Click here to see the model info
Ummm.. Why would there be a contract required? This is for OTA, right, not satellite? Am I missing something?
Plus it's a scratch and dent. Is this really a super deal? Basically 20% off list.
Discussion Starter · #4 ·
you can use this to watch OTA without even contacting directtv...
no contract required is crutchfield doesnt care if you signup with direct-tv through them... they just sell the hardware...... you get the box, call direct-tv yourself..... and make sure you tell them its an HDTV box, or they wont activate the hdtv channels...
I had one of these boxes from crutchfield.
I was ok with the slowness, but the audio stuttering was horrible. the only way you could get rid of the stuttering was if you put it in letterbox mode.
so, unless you want to send the box in for repair right when you get it...
If you can wait till fall get the new model ...
http://www.shopcousinsvideo.com/pantudathdre.html
Tentative Specs;
ATSC Tuner
One Rf Input (Terrestrial)
1080i/480i YPrPb Component Output
2 A/V, S-Video, Optical S/PDIF Outputs
1080i Mode (all formats to 1080i)
Hybrid Mode (480i to 480p, 720p to 1080i)
480i Mode (all formats to 480i)
ATSC Signal Strength Meter
708 CC Compliant
Silver Cabinet
Universal Remote Control
1 - 15 of 15 Posts
Status
