I'm new at this and need to learn a lot about this topic - perhaps someone can help - I purchased a Panasonic DMR-ES46V at SAMs Club and even though the unit was very simple to install via the HDMI cable, playback of my VHS tapes was not very good... the quality was much better on my old Panasonic VHS player... ALso, when playing DVDs on this unit, I could never get the DMR-ES46V to fill the screen on my VIZIO 37" HDTV... the DVD movies were OK as far as quality but the screen shown (set up 16:9) had thick black lines on all sides... if you asked to use "strech" to fill the sides, it distorted the picture... I could not get the unit to give me the resolution and format that I needed.
I am now using my old LiteOn DVD recorder and the screen format is much better, at least the screen is filled on side to side and the top and bottom black lines are much smaller and the picture is not distorted.
I have returned the DMR-ES46V
I would like to upgrade to a DVD/VCR machine but now I don't know what to get.
Any ideas?... Thanks.
