i was wondering if anyone happened to know the dimensions of the plate that attaches to the wall on the peerless articulating wall mount.
to be more specfic, i know that it is about 16 inches wide (to mount on 16 inch studs), but can anyone tell me how tall the mounting bracket is? It doesn't need to be precise...just an idea.
If you are wondering why i want to know this, it is because my studs are centered on 20 inches, so i am going to mount a piece of plywood to the wall across 3 studs and then attach the plasma mount to the plywood. Not the prettiest solution, but i want to minimize the view of the plywood by only making it as tall as it needs to be for the mount.
thanks for any info.
