1 - 3 of 3 Posts
My panny 42phd7uy was reset to factory settings and i lost all my inputs.
Could someone please link or post settings? I've searched the forum and only found one basic one. I would like the detailed version if possible. I used to have the calibrated settings someone posted from using the disk, but i lost them.
Here are color inputs:
Pic menu: Dynamic, cinema, auto, standard
Picture - 0-30
Brightness - 0-30
Sharpness - 0 - 15
Color Temp - Warm, Cool, Auto
Color Mgt - Off/On
Advanced settings Off/On
Also under Signal:
3:2 Pulldown - Off/On
Video NR - Off/On
One other problem ----maybe not, but i noticed it! On the dish network guide, it doesnt go all the way over to the right. I dont remember if it did that before or not. Does your dish network GUIDE fill the whole screen? Mine has the gap at the right (about 2 inches). If this isnt right, how do i fix?
-Glade
1 - 3 of 3 Posts
