No, HD Channels still cannot be adjusted
Originally Posted by richmosar I'm aware that I can't change the aspect ratio using a Comcast HD cable box, but if I were to instead use a Comcast cable card in a Panny 42PX50 TV, will I be able to control the aspect ratio to fill the entire screen for ALL channels so that I can reduce the chances of burn-in from the black bars? Can digital, but non-HD channels be adjusted though? |
Originally Posted by richmosar I have a Comcast Motorola dual-tuner DVR box. I tried the turn-on, turn-off & press menu sequence that was suggested and nothing happened. |
Originally Posted by richmosar HELP! I tried your suggestion to set the 4:3 override to 480i and now I get a "Not Supported Mode" message whn I turn on the cable box. And the worst part is that I can't get back to the menu to undo what I just changed. |
