I have a Marantz 5003 receiver, a panny 3D blu-ray dvd, HD cable box, and xbox 360.
My current configuration is to run XBOX, Blu-Ray, and cable box to the TV via HDMI. I am then running a single optical cable from the TV to the Marantz.
My challenge... of late... is that whether I am watching a Blu Ray, cable, or playing Xbox.. I am not getting anything but 2 speaker stereo out of my home theater. The LFE doesn't kick on at all.
Two weeks ago this configuration was working fine. I dont have any idea what happened.
I called Marantz and did some troubleshooting. I connected the Xbox directly to the receiver via HDMI and all 5.1 speakers kicked in perfectly so I know the Marantz is working. We decided that the problem must be that the Panny TV is receiving the signals from my devices and then passing only 2 speakers back to the Marantz.
I then called Panasonic and the "support" person told me that these TVs are not designed to pass 5.1 signals to any external devices (ie. receiver) unless the signal is a cable or tuner signal that is entering the TV directly and then passing to the receiver.
I am 99.9% confident that this configuration was working perfectly up until recently. I don't know that I changed anything specifically to cause such a dramatic change.
If anyone has any ideas, I would appreciate the help. I don't really want to go back to my "old" configuration of sending an HDMI for each device into the receiver and then a single HDMI to the TV.
(The reason for this is that the Marantz doesn't "translate" the HD cable signal well to the TV. When I change from an HD station to a non-HD signal, I get a "snow storm" on the screen with the audio not impacted)
