I recently got a PAPST 8412 NGMLV fan with a 4 pin full size connector used on a PAL 8045 CPU heatsink on an ECS K7S5A motherboard.
There were 3 wires coming off the fan, going counterclockwise looking at the label side;
1. Red which is the +12V wire
2. Blue acts as ground
3. Purple is maybe a sensor wire, but was attached to the ground wire. It has a splice in the wire that is covered up with heat shrink tubing, but is most likely an NTC Thermistor to regulate speed.
4. Unconnected 4th solder tab on the Fan's PCB
I converted the 4 pin connector to a standard 3 pin motherboard fan connector.
Assuming the purple wire is a thermistor, It should probably be connected to ground (as indicated by their web site pdf).
The question then is does anybody have any suggestions as to where the thermistor is best located? Do I even need/want this thermistor control?
Also is that 4th PCB tab a standard fan sensor point that I can hook up to my motherboard using the standard 3 pin motherboard connector? What is the purpose of that 4th pin if not that? Anyone know?
Ira
Ira
