1 - 20 of 24 Posts
· Registered
My dad has Paradigm monitor 7, matching center and surrounds. All are the latest version with an onkyo 607.
Room is square which sucks its 14x14 with 9 ft ceilings
One smaller entrance way and a fairly large window
75 % MUSIC 25% DVD TV
He wants to buy a Paradigm DSP 3100 because of cost and size which I dont think he even seen one in person. Only reason he wants this sub is he figures he can hear and demo it.
I told him to just get a HSU VTF 1 and he would be much more happy, at least per reviews I have read.
What sub would you recomend? I think if he went with Paradigm he needs at least a DSP 3200. I think the HSU VTF 1 would be better and cheaper.
Whats your thoughts? I told him there is no guarntee they will even have the DSP 3100 to demo. He enjoys music the most so I figure HSU is the way to go. Help me so I can share your insight with him.
· Registered
I have not heard the hsu vtf 3 but i own the hsu vtf 2 currently and i find it a bit lazy for music.
I have heard the paradigm sub 12 which i found a lot superior to my hsu for music... also i own a psb 5i which i found a lot better for music compared to the hsu as well.
From my research/readings i gather rythmik subs are very good for music as well... and very cost effective compared to the paradigms. I have not heard the rythmik yet so cannot confirm my findings.
· Registered
Discussion Starter · #4 ·
thanks for your responses so far budget is under $500 plus or minus. He doesnt care about the brand, just wants it to sound good with his set up. Advice is def. appreciated
this stuff can drive you nutz.
I own an Ultracube 12 and my area is very large. I have it with new atoms front, cc190, adp 170's, onkyo 607. I am very pleased but my sub was also over $800 bucks new. I love the looks of my Ultracube and so does the gf. I think its great with music and descent with movie. Some would want more slam for ht I think...
· Registered
I currently have a psb 5i
Another sub the svs sb12 plus (now discontinued) is very good for music... it does not go low again its sealed but for movies it does not lose steam and sounded decent with movies as well.
· Registered
i have a hsu vtf2 MK3 and it sounds awesome for music once you dial in the levels correctly. i dont use it anymore with my LS6s but when i had my MA RS6s i would sometimes go back and forth and would think my speakers had gained extra bass somehow but then realized i had my system set to 2.1 and the sub was blending almost seamlessly.
· Registered
I have a DSP-3100. Its the first piece i bought for my HT. I got it for 400. I love it and its made a world of difference for my HT. My room is a 22 x 22 with cathedral ceilings and the 3100 is not lacking for me. I am no expert. You should be able to get a 3200 for that price. I just added some Signature S2's and they sound great together. I have not listened to a HSU so i cant comment if that is better or worse. The 3100 can be purchased with the PBK (perfect base kit) which will tune your sub to your room.
· Registered
I have a 3100 as a loaner until the 3400 arrives.
I find it's very good to excellent for music and very good for HT. Musically it's great for all but the lowest bass and blends very well with my Monitor 9s. It does tend to stumble a bit with very deep HT effects, like war of the worlds, for example but is otherwise fine.
One thing I like about the dsp series is that they are front ported which makes placement easier. I intend to build the 3400 into a cabinet when it arrives.
Doug
· Registered
Discussion Starter · #11 ·
njandy you think the 3200 can be had in the $400 range new? where do you shop? mike I live near princeton but dont mind driving. Let me know I went over the bridge into pa for m Ultracube and had to haggle and use another dealer farther away to get the best price.
How would the dsp 3100 3200 compare with that cheaper ed sub mentioned above?
· Registered
try a more articulate sub side by side on the system you will notice the difference immediately... that's what happened to me and i am in the market for another sub.
· Registered
I apologize in advance if this seems like dumb advice. Living in central NJ (as your tag says) you will assuredly be able to find a quality subwoofer in the used market. Subs seem to hold up pretty well through one or two previous owners. As long as it's not too old, it should be plug and play, so to speak.
My rationale: An $800 sub (used for $500) will usually outperform a $500 new sub.
That said...If I had the money, I would never buy a single used item again.
I previously owned a $499 subwoofer and in comparison to a $1,000 subwoofer, it seemed like a $50 sub. Just remember that price is only the amount you pay, and doesn't necessarily dictate results.
Just for reference, is he looking to maximize SPL, or just even out the sound and add some dynamic?
· Registered
Geek,
I got mine from the sound exchange in sommerville. Mine was a floor demo and they were willing to negiotiate. I have been seeing 3200's in the 4's pretty regularly. I just found this site (google is your friend) http://www.tsto.com/Paradigm_DSP_340...fer_p/3231.htm that has the 3400 in your price range and the 3100 well below.
Andy
· Registered
Discussion Starter · #15 ·
Even out the sound... He's in his 70's and does'nt crank it up, at least not when I am there. haha The focus would def. be on music and rounding out the sound with good quality bass. Guys thank you for your responses!
· Registered
Discussion Starter · #16 ·
Originally Posted by njandy /forum/post/18240002
Geek,
Andy
Hi Andy & thanks for your responses back. I bought my setup there minus the subwoofer. Jerry's so called sales price was the same as other dealers asking price. I really do like Jerry but he is fairly far away from me and another dealer is within 10 minutes. He took care of me on the speakers price wise but the sub price was just a turn off. Otherwise I have nothing bad to say about that place or the owner. You just need to neg with him.
What speakers do you own? I live in Ewing if you ever wanted to hear what my Atoms sounded like with my Ultracube 12. For small speakers I feel they sound excellent. But after listening to my father Monitor 7's there is a huge difference in sound quality. And he does'nt have a sub yet!
· Registered
HSU has my vote, but SVS and eD are excellent choices as well.
· Registered
I would suggest that you make sure any sub you buy has a single band parametric eq. Due to room being square it is going to have a huge peak in the 60 hz range that you will want to cut using the filter. A little higher in price, but the Rythmik F12G has a parametric.
· Registered
Discussion Starter · #19 ·
Well I went and auditioned the DSP 3100 which in my opinion sucked. The room was pretty large but the DSP was almost at its max and had little to offer. I ddont know how someone could be excited over this sub especialy msrp. No DSP 3200 to try and when I asked about the DSP 3400 he said its not hooked up. It's like dude grab a cable and llet me hear and be the judge. He said he only sold a few and that the Ultracube 12 smokes it. Well thats nice to hear as I onw the Ultracube but I did want to give it a listen. I dont know why they keep this salesman as he just doesnt know ****. He was like I sell tons of 3100 and no 3200, I was like why. He said because once a client gets into that price range they buy better Paradigm subs like the Ultracube. I asked him about new lines of Paradigm speakers and he was clueless. I should work there! Anyway the DSP 3100 did not excited me in the slightest degree.
No way my dad is going to buy an ED sub so it looks like an HSU model. Only because he has heard of them and read reviews in magazines. I dont know what to do...
And that salesman just bothers me... Maybe he wants a major install sale and my potential sub sale is a waste of his time. He should be glad I stopped in as I never see any customers in there. blah blah blah
· Registered
Wow stay away from the studio 20's and up then. I listened to studio 20's next to upper spectrum monitors and it was like air vs mud. Ended up with studio 60's used.
1 - 20 of 24 Posts
