Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
Does anybody have any experince with Paradigm Monitor 70P speakers? I want to use them with a Denon 3300. Also does anyone know what a good price would be for these speakers. Thank You Mike
· Registered
I have not heard the 70p, but I did compare the Monitor 70 to the Paradigm Legend and others. I just hooked up my Legends (obviously the ones I chose) and they sound even better in my house than they did at the store. They list for about $900, but you can get them for less. I think they sound better than any other pair of speakers under $1500, even ones without built in subs. If you like Paradigm and want a small, powered sub tower I would check out the Legends, especially if you are using them in a home theater setup.
-Gergg
· Registered
Discussion Starter · #3 ·
Well I made a decision and bought a Paradigm Reference s-40. They sounded good in the store and great when I got them home. They are super clean and clear. For bass I got the Definitive audio model 80 sub. Haven't hook that up yet. These speakers should work out just fine because I listen to music more than explosions
1 - 3 of 3 Posts
Status
