Originally Posted by Dbuudo07 /forum/post/15444112
I'm curious as to why this sub hasn't had more buzz. From the specs, it looks like it will eat most subs out there. Is it the price? Maybe... Personally, I'm interested in it and the PBK-1.
I think balanced down to 9hz is freaking insane!
Originally Posted by Dbuudo07 /forum/post/15444915
If it can be flat down to 9hz, which I'm hoping for, it will be amazing. I don't think they'd advertise 9hz DIN, with a 15hz roll off. I could be naïve, but that would make them look pretty foolish, especially if its going to be reviewed. I'm hoping for these to be honest numbers because I want a sealed sub that's really good for home theater. This is why I keep looking at the jl audio subs. But I'll wait to listen to it and hope some reviews are available by magazines and members like Craigsub. Here's hoping all that power will help those numbers be accurate. Just imagine if it achieves 9hz at -3db!
Originally Posted by chengbin /forum/post/15446069
3. What if it's -3dB at 9Hz at 50dB? A subwoofer need to produce 110dB at 9Hz for useable 9Hz output. I can tell you that by rough estimate, it will take at least 5 SUB25 to produce 9Hz at 110dB.
I'm sure the SUB25 will be a fantastic sub, but the price/performance ratio is nowhere near ID sub's. I'm not even sure if it can outperform the SVS PB13 Ultra, an example of an excellent ID sub.
Originally Posted by croseiv /forum/post/15446142
I'll keep my dual Ultras!![]()
Originally Posted by chengbin /forum/post/15454131
A superbly designed ported sub, like the PB13, will sound as good, if not better, than a sealed sub.
Read this. Read through all if you want, but post 1, 7, and 9 are the most significant.
http://www.***************.com/fusio...d/138686/tp/1/
Originally Posted by Dbuudo07 /forum/post/15456839
Thanks for the link. It was a really good idea. I wonder if they got together again for the eq, same position, treated room test. From what I read though, it seems that the price was the final ticket to victory. Output and quality were almost the same between the f113 and the pb13. Output going to to the ultra and quality going to the fathom, and the quality is what I'm interested in. I've been in a room with 4 subs and the output was great, but it wasn't as tight as I'd like. But I will say that svs did do a fantastic job with that sub. The amp needs to be replaced from the sounds of it. I would like to hear one properly set up. If anyone in the Toronto, GTA area is willing to let me audition it in their home, I'll bring the wine(or beverage of choice).
Question. Let's say the SUB 25 can't do 9hz at 110db, but it does at 100db. Are there any subs that can do that? I'm just asking. I haven't done any measurements to know. With all that power available and a 3 inch excursion, don't you think that would help its chances?
Originally Posted by chengbin /forum/post/15457124
The only bad thing about that review is that they tested the PB13 in 10Hz mode. 15Hz mode is SVS's best mode because it gives up 1-2dB output above 20Hz for 10dB more output in around 15Hz range. GP tests have shown that the 10Hz mode gives 0.5Hz more extensive at a huge loss of output. GP tests show that the PB13 have about 6dB more output than the F113 starting below 40Hz.
Truthfully, while the F113 is a "better" music sub, the difference is splitting hairs. Unless you really listen for it, you won't tell a difference.
100dB at 9Hz is impossible as well. It might barely exceed 100dB at 20Hz at best. It will produce 90-92dB at best at 9hz.
