I am about to purchase either the 40's or 60's. I have only heard the speakers for about 1/2 hour. I am 200 miles from the dealer. I went to the dealers to purchase the 60's, but ended up unsure after listening to the 40's. Both work out to be the same price with the premier stands for the 40's ($1080 Cdn).
I assumed that the sound of the 60's would be almost the same as the 40's but with more base for the 60's because of the larger size . (The have exactly the same speaker setup)
But the sound is very different between the two speakers.
I was wondering if anyone else had the same problem . Maybe going in for the 60's and ending up with the 40's or vice versa.
I will be going back for extended listening in a week or so with my music.
I though the 40's seemed clearer, not sure if that is the correct description. But I have also read that some people found the sound too bright and after a period of time they had did not like them.
Because of the distance I cannot take them home for a demo or drop over for a listen anytime I want.
Any opinions would be of help. I know it is up to what I like, etc. But opinions do help.
Bob
Bob
