Hello all,
Thank you I. Advance for your help and I'm sure this isn't the first time this has come up. My brother got a nice 5.1 package because he got a good deal and doesn't know a ton about audio. I am an amateur myself and could use a hand setting up his passive sub. I flew to the Midwest and helped my brother set his system up to a mid level denon receiver but I was shocked to see his sub is passive. Does he need to buy a sub amp plate or is there a way to set his sub up to the second zone as if bi-amping? From my understanding there is no adapter from speaker wire to a sub cable because the sub line is a form of RCA and doesn't carry a strong enough current through it. Any suggestions on how to hook it up? Can he buy a cheap stereo receiver and use his denon as a pre? Can he bypass getting anything extra? Or does he need to bite the proverbial bullet and get a sub amp? If so any suggestions on inexpensive but adequate amps? Thanks again!
A
A
