PC buying help...
777 Views 16 Replies 5 Participants Last post by  MSmith83
Hey guys, I was hoping I could get some advice. I am thinking of purchasing a new PC for home use. I am NOT looking for a bleeding edge PC...just a fairly robust PC that will allow me to game a bit, use it for music, surfing, etc (my last PC was a P3 733 :) ). My budget is ~ 1800 bux; I don't neccesarily need a new monitor (but the new widescreens look good :) ).
I would appreciate some advice on good companies, features to look out for, good compromises between performance and value, etc. Thanks in advance.
Status
Not open for further replies.
1 - 17 of 17 Posts
I seen a 3800 Dual Core AMD, 512 ram, 200 gig HD, XP for $440 at Fry's. I'd pop in another 512 meg o ram and a $200-$300 video card and bam your going strong for $800.
Build your own. Best bang for your buck by far and you'll learn a lot in the process.
newegg.com is a great place to look for parts. Be sure to read the customer reviews on the motherboards and processors before buying.
If you don't want to build then pretty much all computer companies are the same. They all get their parts from pretty much the same places and offer more or less the same support. Just do some research on which models fall into your range and buy the one that gives you the most features/performance. Dell is the most popular but you can usually get better deals at B&M stores (after the rebates come back). Personally I'd steer clear of Emachines and Sony computers but others are perfrectly happy with them.
I have nothing against build your own, but some systems like I mentioned are cheaper to build in that fashion. When someone says build your own... they a lot of time assume no cost for XP and a new install copy isn't that cheap. Do you want to be legal or illegal? And if you go the later are you going to get updates properly, sure there are work arounds... but the system I mentioned I cannot build for that cost.
I haven’t done a Sony before, but I did an E-Machine, ran fine and still runs fine to this day.
Thanks for the replies guys. I was gonna add '...warranty and customer support are important to me.' :) don't have the time or energy to be bleeding edge (looking for latest drivers, overclocking to instabiity, spending an extra 500 bux to go up 0.4 gigahertz, etc). Dell, Gateway, HP, etc would be fine w me (customer support).
Are there any substantive differences between AMD and Intel w thier perfomance CPUs (i'd be looking at the cheapest of their high end stuff-budgjet permitting)?
ZipZoomFly is a good place to purchase parts from. Free 2 day shipping on most products and they have among the lowest prices, often the lowest.
I just built my brother a PC with the following specs:
Windows XP Pro
NEC Dual Layer DVD+-RW Drive
EVGA 7900 GT CO Superclock
Asus A8N-SLI Deluxe Motherboard
Creative X-Fi Xtreme Music Sound Card
OCZ DDR400 (2-3-2-5 1T) 2GB of RAM
Thermaltake 500 Watt SLI Power Supply
Logitech Cordless Keyboard and Mouse
2 300GB Maxtor Hard Drives
AMD Athlon 4000+ San Diego
All that was bought for just under $1700. Not quite as fast as my machine :), but it certainly handles anything thrown at it.
You don't necessarily have to get a machine as powerful, but I recommend getting at least 2 GB of RAM, 3500+ Athlon processor and 7900 GT if you are serious about gaming.
See less See more
If you must buy from a vendor, I would go with a Dell. As for processor brand, AMDs are currently better for gaming but Dell only uses Intels. However, Intel processors will get the job done. A downside is that Dell's PC that is priced comparatively to the aforementioned PC I recently built will perform significantly worse in games.
See less See more
^ And that is why I would go HP, instead of Dell, AMD's... Circuit City/Fry's carry the HP's, look at something 3500+ and above proc wise, imo. If you want the 3d games, you will have to buy a card and insert that yourself, imo a must. Make sure to get a system that has a PCI Express slot for the video card.
Just to give the OP more food for thought:
$200 videocards like the x1800GTO's or 6800GS's and 1 gig can still play all the new games (1280x1024 2xAA, 4-8AF) and you can act as serious about it as you want. You may have to give up a feature or two that imo the new latest features aren't worth it anyway, more hype then reward for the performance hit. Give me high-rez textures, High Rez, AA and AF and I'm good to go, the HDR and Soft Shadow stuff doesn't really help the immersion for me anyway. The 7900GT can't even guarantee all features with optimal frames...
Sure they can play the newest games, but at medium settings if you don't want constant 1-2 second pauses. Even at low resolutions like 1360x768, 1 GB of RAM causes pauses in newest games when using high-res textures. The price difference between 1 GB and 2GB isn't that big anyway. BTW, a single 7900 GT can play any game with all features at a good frame rate, so long as the resolution isn't high like 1920x1080.
See less See more
See I have that system and one above that more in your recommended specs. In the real-word or at my place the better system is just a wee bit better. A 3500+, 1Gig, 6800GS system isn't playing games with what games call medium settings, well above that. You still get the High Rez textures, 1280x1024, AA, AF, shadows (less soft) at almost nearly the same frames.
What starts to hit the frames in most games are HDR and Soft Shadows (HL2 Lost coast the exception that still runs great) but the 7800GT system chokes as well with those features, the 7900GT would be right in line predictably as well. I know we all like to think there are these huge gapping differences between video cards, but I feel that is always overblown, now maybe a $500 video card can get you more a noticeable difference but time on this earth tells me that gain isn't worth the extra jack and is meant for people where money simply isn't an object or a player is a little reckless with their wallet.
The system I mentioned sounds like what the OP is squarely after.
See less See more
I configured a moderate power AMD-based computer on hp.com for my folks and was more than satisfied. I've done the same thing with Dell for my Uncle and I would definitely go with HP again.
Go with an X2 CPU, 1GB DDR400, throw in a 7900GT and you're set for a while.
I hear ya, but the video card and system RAM can make a world of difference, especially system RAM. When I had 1 GB of system RAM and a 256 MB video card, games like FEAR would pause constantly when loading textures for new areas. I had to scale the texture quality to medium in order to have a smooth gameplay experience. The same holds for Doom 3 and its expansion, Quake 4, Half-Life 2, etc. I can't even imagine how GRAW handles 1 GB of system RAM with a 256 MB video card at high quality textures. Your average framerate won't change when moving from 1 GB to 2 GB, but the gameplay experience is much smoother and more enjoyable.
See less See more
Thanks for the advive all. I have seriously thought about the Dell (this may be a gimmick, but they have this utility called safe disk, I believe when constantly mirrors the hard drive...i.e.-painless backup), but-and I may be a victim of marketing here-with Vista coming up and its ability to allow for 64 bit programs to be easily used, I was thinking about getting a PC w an Althon dual core.
HS...you are right; I don't need the highest resolution capable PC out there. If I could put this in car terms, I want something that has good 0-60 times, but doesn't have to be the quickest to 60...so I would take a 'Vette Z06 that hits it in about 3.7 secs for about $70K, rather than the Ferrari Enzo which may shave 0.4 secs but costs a milloin bucks. :)
It's not really about resolution, as any current game can really tax a graphics card even at 1024x768. This article shows how big that difference can be. My recommendation of a 7900 GT is only so you can play future games at acceptable quality settings. As for my 2 GB of RAM recommendation, 1 GB will guarantee in-game stutters with certain quality textures, and that certainly isn't fun. I'm just trying to save you the headache of wanting to upgrade in a few months. When I was careful in how much I spent on PCs, I certainly got that immediate want to upgrade after buying underpowered hardware. Of course, this is all irrelevant if using some medium quality settings isn't a problem for you.
My base processor at this time would be a AMD 3800 Dual Core. Not a have to have but that is where I would start, gives you a little something extra to look forward to when DC patches of games are released.
To Smith, I have no problems with the 7900GT or 2 Gig's of ram. But I'm just stating if budget becomes a problem there are $100 cheaper cards and that 1 gig of ram (~ another $100) can get you through looking just fine and dandy and well with Vista and DX10 coming you might be better off saving that $100 on the video card now and get a new one early next year. But hey if you got the $$$ what Smith is saying isn't a lie, both of those are better to have.
Personally I play everything at 1280x1024 and change options from there to satisfy my FPS. That goes for the 3700+ w/GS6800 and 3700+ w/7800GT. The AMD 2800+ w/9800Pro however attempts to satisfy at 1280x1024 but on the top-end games it many times has to settle for 1024x768 or 1152x8?? (can't recall second number). Why 1280x1024? Overall value, I get an immediate image quality bump by matching my LCD's fixed panel resolution of 1280x1024, if I don't do this I take a pretty noticeable quality hit. I've already mentioned the gfx features I favor and in which order I use them already.
IMO fixed panel monitors now play a key role in all of this, my next LCD will be a windscreen and I have to be considerate of it's resolution:
They have options for:
2560x1024
1920x1200
1280x768
1280x720
1366x768
1680x1050
1440x900
I'm considering either of the last two. What I do know whichever panel I pick that will be my new default resolution for everything, desktop and games. I for example do not consider 1920x1200 because I feel I'll be taxing my performance in games too much using that as my new standard. The last two are quality enough for me and with strong enough but reasonably priced hardware I will be able to push those pixels around without losing mucho frames per.
THAT DELL BACKUP THINGY:
You want to really be backed up? Buy Ghost and an External USB Hard Drive and just do it with class and total coverage. A CD or a DVD can’t ever bring it all back for you.
See less See more
Resolution of a fixed-pixel display is indeed key. I play older titles like Half-Life 2 and Doom 3 on my 1080p DLP. However, I play newer games on my 1366x768 LCD. As tempting as a 1080p or 1200p display is, I also don't think the quality settings that reasonable hardware permits justifies gaming on these displays. To me, the resolution difference between 1360x768 and 1920x1080 isn't that big despite having double the pixels with the latter. Resolution is one thing that enthusiasts make a big deal out of, but high resolutions just aren't feasible. Give me high quality graphics settings well before an increase in resolution.
1 - 17 of 17 Posts
Status
