Well that's the point dude i don't have a way to change the way the device works. It sounds like it's not even hand shaking it's just letting your projector do it or whatever bad on unknown rules. You might have to get in tehre and change the firmware to get the splitter to do the handshake if that's even possible. Or put in some controls so you point it at the right devices idk.
You're talking about an engineers work. I gave you the level 1 IT work around. I understand what you want but that is vastly beyond my technical expertise to give you and probably beyond yours to implement.
Plug two separate outputs into the splitter if you want. That might work. Who knows how the thing works. Try it if you have not, you should have. If you've been trying to get your matrix to split the audio and video feed i have no words....
i will try the settings in
Well that's the point dude i don't have a way to change the way the device works. It sounds like it's not even hand shaking it's just letting your projector do it or whatever based on unknown rules. You might have to get in tehre and change the firmware to get the splitter to do the handshake if that's even possible. Or put in some controls so you point it at the right devices idk.
I just learned about MPC BE yesterday. I am going to try to let that be the player. I have been using Kodi and VLC without DTS and Dolby digital audio. My goal is to listen to movies in the correct format in my 5.1 audio system. I thought it would be as simple as adding an HDMI video card to my PC that I was just using VGA out from the motherboard and stereo analog audio out.
I will not be trying to hack the switcher for any reason. It passes digital PCM audio because that is what the video card is sending it. If I can figure out how to configure the PC to send the native bitstream of the file format, just like the other devices in the system, the switcher will pass that and extract it to my preamp processor that has the DAC.
What I found out is that a computer will not let you set manually the output like a Blu-ray player or satellite receiver or high-end audio disc player for a novice like me. I guess it is trying to be smart and tell me what I need. The IT portion of this is my weakness.
Besides that, I really don't understand when you said I can send audio separately from video when the video card has one HDMI output. I am just not seeing that diagram in my head. The switcher is what is doing that for me with all of my devices. It is sending video to the projector and audio to my preamp processor using an HDMI input and an HDMI output with a toslink output separate.
I think I need to go back to the MPCBE settings and figure that out.
I did not think this would be so difficult to do. I do not understand the logic behind making this a chore.
