I have a homemade MCE computer with ATI Radeon 9600 adpater connected to a Samsung DLP(720p) via a DVI to HDMI cable. I have this computer in a closet and administer it with another PC using VNC. The problem is that the computer would "sometimes" hang while booting with nothing displayed on the TV. I would then take the PC to my workbench connect it to a monitor and it would then boot just fine. After some experimenting I discovered that the PC will not boot if a monitor is not connected. I tried changing the monitor driver to a standard VGA monitor (it was "plug-n-play") and then the computer would boot with no monitor attached. However with this monitor type I could not select the custom resolution (1152x648) I needed. I am using the ATI control panel to create my custom resolution.
Here's what I think I need. I need the PC to ignore what monitor (if any) is connected during bootup and still use the pre-set custom resolution that had been saved. The PC and video card are trying to be too smart with detecting monitors and adjusting resolutions. In old versions of Windows you used to be able to specify something like "ignore plug-n-play" for the monitor. Another wierd thing with this setup is that when I first connected the TV to the PC I was able to see the initial BIOS screen when booting, now (when it's working) I don't see anything on the screen(except something like unsupported resolution) until it boots into WinXP. How/why was I able to see the initial BIOS boot screen before?
Any help or guidance with this problem would be greatly appreciated. Many years ago I was very active with HTPCs, custom resolutions, Powerstrip, etc. Now I would just like to connect my DLP HDTV to a MCE computer. MCE does a decent job of playing ripped DVDs and HD stream files (when my system doesn't hang during bootup). Thanks.
Jay
Jay
