You could have a defective unit. Have you tried the analog outputs to see if you get any sound at all via the B&K?
Also under the Audio/Video Setup here are a few tricks that might help. Turn HDMI audio to off if you are not using it. Set the surround mode to Stereo (this will not affect true 5.1 sound tracks). Set all of the audio type settings to RAW for DD and DTS. Use PCM for all the others unless your receiver can decode WMV, FLAC etc.. When you are all done changing the settings make sure to exit using the Save button.
Hope this helps you out a bit.
Laters,
Jeff
Laters,
Jeff
