1 - 2 of 2 Posts
Hello there - just registered so my 1st day in forum
I recently stumbled across the Muse PC21 PCI TA2021 amp and i am thinking to slapping a cheap PC for guest room/den using this and some bookshelf speakers. I would want to work out the audio 1st as it doesn't need to be a high end machine but i like it musical sounding from the savings
http://www.ebay.com/itm/MUSE-PC21-T-...item19c71e061c
My questions are
1. Do you think amplifier being housed in a PC case makes noise a problem? I am going integrated graphics (Llano as these could actually do low resolution gaming even), selecting silent fans, etc
2. For strictly 2.0 (maybe add a sub at the most) is my choice of DAC in the Musiland Monitor 01 US good, overkill or could be doing better?
http://www.dinodirect.com/musiland-s...iter01-us.html
3. Ok for speaker selection - this would be for near field listening (user hardly 2-3 feet away from speakers) but nonetheless i am picking efficient speakers in the 89dB and above range so which of these would be good for the $$ Had owned some Polks , liked the sound but if spending more is worth it then
1. 89db Polk Audio M10 $72
http://www.amazon.com/Polk-Audio-M10...32630&sr=1-205
2. 90dB Infinity Primus P162 $150
http://www.crutchfield.com/p_108P162...le.html?tp=186
4. I was hoping to settle amp + speakers + DAC at the $200 mark but if slightly more reaps rewards i am game (but not too much heh)
1 - 2 of 2 Posts
