Status
Not open for further replies.
1 - 8 of 8 Posts
I have the PlayTV PVR TV card and I can't figure out how to get sound with the Revo card. The PlayTV card has an analog audio out but the Revo doesn't have an audio in plug. I can't plug into the input on the motherboard because I had to disable it for the Revo to work.
Surely someone has figured this out?
TIA,
Gary
Discussion Starter · #3 ·
The PlayTV PVR has an analog out like a CD-ROM analog out. The only input I can see on the Revo card is a 1/8 Stereo mini jack. Is there a cable I can buy that goes from the TV card to a 1/8 mini jack?
Should be easy enough to fab one, Gary. You could even splice a severed (internal analog) audio cable to a severed 3.5mm cable if you don't want to solder...
Discussion Starter · #7 ·
The plug on the TV card is audio-in, not out. I am using it as audio-in.
edit: The audio out is internal, on-board. It uses a plug like a CD-ROM audio cable.
I guess I'm surprised that the solution is so hokey. Why don't they route audio across the MB like DVD-ROM and CD-ROM?
Ouch. Looks like your SOL unless you go with Elvis's idea and work a wire from the internal output of the card to the external input of the Revo.
peace
1 - 8 of 8 Posts
Status
