Status
Not open for further replies.
1 - 4 of 4 Posts
Hi folks, I just got myself an Ipaq PPC3950, i have loaded Tv Remote Control from PDAwin and all is fine, it controls my tv etc no problem, the problem is how or what do i need to get it to control my Home Theatre Pc, i use it for sat tv, dvd, mps etc.. Do i need the Irman gadet?
Many Thanks
You do need some type of IR input device for the PC... I use the slinke which also controls my 2 CD jukeboxes. Also, you'll want to use a program called girder. Do a search in the HTPC forum for more info, or go here:
www.girder.nl
Good luck.
David's got it - you need two things:
1) A device to receive the IR into your PC (IRMan, Slink-e, etc)
2) Software to process the IR and performs tasks (Girder is my favorite)
I use my slinke to coordinate the audio control via X10 RF remote. Being a big Homeseer user, whcih has a slinke plug-in, it also benefits my home automation setup.
1 - 4 of 4 Posts
Status
