PDP 6070 blue blinking power on indicator
638 Views 3 Replies 3 Participants Last post by  jhenry
When in standby mode (solid red light) the blue power on indicator will start to blink after a few hours. It blinks 12 times then pauses and continues this pattern. Anyone have this happen to them or know what the 12 blinks may be telling me? Have a call into Pioneer but they seemed less then helpful but did say they would call me back sometime??
Status
Not open for further replies.
1 - 4 of 4 Posts
Disable the TV Guide by entering all zeros in the zipcode.
12 blinks also means Do a search and you will find the answer here
http://www.avsforum.com/avs-vb/showthread.php?t=686602
Almost anything you may need to know has most likely been posted use the search feature before posting a new thread.
Welcome and hope you are enjoying your new panel, chime in on the 6070 thread and donate some feedback.
Thanks guys -- Will Disable TV guide and see what happens. For the record I tried the search first but didn't find th e answer until after I posted! :)
1 - 4 of 4 Posts
Status
