Peerless-AV HD Flow, Pro Wireless HDMI / Component Video Kit / HDS200
This is a Peerless AV HD Flow HDS200 kit. It is in like new condition and comes with everything as new (Remote, Power Supplies, VGA/Component adapter, IR Receiver, IR Emitters and stands). It has seen very little use as I initially installed it in a clients summer home but do to a recent renovation we are now able to hard wire HDMI's, so they are for sale. If your looking, you know that these are very hard to find as the new HDS300's were just released last month and they sell for $600.00 as did these when new. I'm asking $250.00 or best offer. PM me or text me at 631-428-4177 if interested. Info on product below...
SOLD
INFO:
The Peerless AV HDS200 HD Flow Pro Wireless Multimedia Kit provides immaculate, wireless connectivity between your HDTV and set-top box, Blu-ray player, game console, etc. The wireless transmitter connects to the media source and sends the signal to the receiver, which is connected to your HDTV. The HDS200 signal can span an impressive distance of 131'. It supports Full HD 1080p 60Hz wireless streaming, passive 3D transmission for passive non-shutter glasses, and 5.1 channel digital audio with Dolby and DTS. Plus, it's equipped with dual HDMI inputs and Wi-Fi 802.11n wireless connectivity.
There are several benefits afforded by the HDS200. One transmitter can send a wireless signal via Wi-Fi to four separate receivers (additional receiver purchases required). It provides the flexibility to stream media signals from room to room. In fact, the signal is strong enough to travel from inside to outside, through walls and through ceilings. There are multiple interfaces to choose from, including HDMI and composite inputs. Plus, the remote control can operate the transmitter from another room, thanks to the hardware featured in the wireless receiver. The HDS200 transmitter and receiver feature improved heat dissipation as well, which allows you to place transmitter or receivers at any angle.
Both transmitter and receiver are designed for quick setup and plug-and-play functionality. The wireless signal transfers are ultra-fast, secure and they resist interference. The HDS200 provides an entertainment experience that's free from the cluttered chaos of pendulous AV cables running between your media sources and HDTV. The system also features built in key slots for discreet wall mounting. Plus, there's virtually no latency and an included IR extender helps reception when receivers are obscured.
Enjoy digital entertainment without cables, sent in Full HD 1080p resolution and with 5.1-channel digital sound quality
HDS200 also supports passive 3D transmission for passive non-shutter glasses
Place your HDTV anywhere in your home, on any wall. The HD Flow receiver can be discretely mounted behind the TV
Wirelessly connect your Blu-ray, DVD player, video game console, set top box or other media devices
Connects to all of your HD receivers and electronic media players via two HDMI inputs for full digital HD connection from a single source
Plug-and-play connectivity for easy setup
Included IR extender helps reception when receivers are obscured
Improved heat dissipation now allows you to place transmitter or receivers at any angle
Built in key slots for discreet wall mounting
SOLD
INFO:
