Peerless Tech LT150 Mount
436 Views 3 Replies 3 Participants Last post by  AfroCreame
Just a quick quesiton. I just ordered this mount to attach my LT150 on the ceiling. Does anyone know if you can run cables through the "Shaft". TIA
Blake
Status
Not open for further replies.
1 - 4 of 4 Posts
If you talking about the Peerless PADP-NC4 and the PJRL-100 you should be able to...
I'm looking assembly instructions right now and it looks like you can.
You can call Peerless direct at 1-800-728-0307
http://www.peerlessindustries.com
The mount your referring to is the PJRL-NC4. And yes it does have a generous center hole for running cables. I just mounted mine on Saturday.
Jon
Great! Thanks for the input!
1 - 4 of 4 Posts
Status
