Hi guys,
Over the weekend I redid the set full setup on my machine, except physical movement.
After about 15 hours of total work I have a very square screen. All the dots are almost over each other (and I do not even have point convergence board), except in the bottom right and that should be easy to fix. I had to adjust the tilt-phase in the service menu to get such a square screen
What I am seeing now is like a very faint outline when a dark image is against a bright one. Almost like a faint ghost image of each color. Most people may not recognize it but I do. It has also appeared on previously stored memory settings so I know it must be something with the mechanical setup.
I can't figure it out. The dots look tight, and the astig looks great. I may be missing something.
a) I have checked the cabling
b) turned off different colors of and it still appears
I am almost afraid to mess with it because everything looks sooo good. I watched HDTV football yesterday and that redeemed my faith in my projector.
clopez
clopez
