4081 - 4100 of 4711 Posts
I hate VHF. I can get 6 in Chester Springs, but it took them to do a major increase in power to make it happen.
WHYY is impossible, but I get NJN 23 clear as a bell, although it's much further away and I'm "behind" Bacton Hill (a 550' hill)
Used to get channel 6 when they where on UHF. After the transition and they went to VHF, never seen ABC channel 6 again. I am in central NJ (45 miles out). I have the same issue with NY VHF channels. Reception via UHF was great, so why did the government allow stations to go back to VHF which is much harder to receive.
because some folks at the FCC failed proper mathematics class. Here is a editorial from Mike Kohl at global-cm.net back in 2009
We have been attempting to cover the fallout from the June 12th shutoff of full power analog television signals across the United States. It turns out that most of the public WAS ready for the transition, and that television stations were equally ready for that plug to be pulled, forcing everyone into permanent digital mode. But it turns out that flawed engineering data at the FCC has caused a major fiasco with stations that are now using VHF channels 2 to 13 for digital. Most visible examples include channel 13 in Baltimore, which was doing fine with its analog VHF channel, and equally well if not even better with their temporary UHF digital frequency. Once they shut off analog on VHF, turned off the temporary UHF digital signal, and then turned on VHF digital, a nasty surprise was found. As an outsider, all I can see is that highly visible engineering people must have been sleeping through much of their elementary school mathematics classes, and missed the parts on multiplication and division. Let's see if the rest of you can pass this test: If a UHF TV station was allowed to transmit 5 million watts video power in analog, and then given permission to use 1 million watts for digital, that would mean that the digital signal is using 20% of the power of previous analog signal. Suppose that a VHF station on channel 13 was previously transmitting at the maximum 316 Kw allowed for analog (just as UHF channels were allowed 5000 Kw on analog), would it not make a little bit of sense that the digital allotment should be somewhere near 20% of the previous analog power output? That number would be just over 60 Kw in most circumstances. Why were VHF channels given power outputs typically between 10 and 30 Kw? Did nobody realize that you would get extremely reduced coverage at a fraction of the power? And there was no real-world testing situation in many cases to see if digital VHF performance was adequate at proposed power levels?? Somewhere in the explanation should include the word "idiot", in my humble opinion. At least the FCC is now acting at previously unheard of speed to respond to broadcasters that are struggling with the power levels authorized, and giving them permission to crank up the power. It's still sort of an experimental process, with those complaining the loudest getting the attention (and permission) to increase power levels. Let's hope that things work out for the best sooner than later. Next is the plan to allow fill-in translators and other rebroadcasters to go on the air in areas that digital is now not working---after being satisfactory for analog signals for many years. Another debacle that will take a long time to straighten our!
The issue with VHF Low is interference. Also Channel 6 chose VHF 6 in the Digital RF station rounds. They were on 64 pre-2009 which was taken away in 2009
Thanks. Interesting write up. Sounds more like the government did not have any common sense or just couldn't leave well enough alone!
One thing I forgot to note...Mike is/was a satellite dealer years ago and use to do installs of large commercial satellite dishes in Alaska and also did some work on the Mt Wilson (LA) Antenna farm years ago. So he knows his stuff. Here is a couple articles
http://www.global-cm.net/news&views200606.html
http://www.global-cm.net/news&views20061226.html
http://global-cm.net/news&views20080610.html
Anywho the thing with VHF Low is most of the stations that use it are smaller markets that could save money by not moving to a different station. Also in those areas most folks already had outdoor antennas so it wasnt that much of an issue. As example a few of these network (Big 4) stations right now on VHF Low
-Bangor Maine (which right now is very unique as you only need a VHF antenna to get all the stations. All 4 commercial and PBS are on VHF. A couple have UHF translators but they are on 2 (NBC), 13 (CBS), 7 (ABC/FOX) and 9 (PBS)
-North Platte, Nebraska (they actually have 2..NBC on 2 and ABC on 6)
-Eureka, CA
-Calumet, MI (UP of Michigan)
-Butte, Montana (2 of them..CBS on 5 and NBC on 6)
-Glendive, MT (KXGN flash cut on 6/17/09...they never had a "companion" channel
-Lead, SD (satellite of Rapid City station)
-Memphis, TN
-Bristol, VA (Tri Cities)
-Weston, WV
-Albany, NY
-Quad CIties and Des Moines, IA also have VHF Low stations but have UHF translators also
So as you can see outside of Philly I would say Albany being the next biggest market that has a VHF Low network affiliate. What is nuts is there are some stations who decided to cash in their chips and move from UHF or VHF High to VHF Low in exchange for a payout including the PBS stations in Pittsburgh (WQED), Boston (WGBH) Los Angeles and Rhode Island. So that outta be interesting when folks with antennas there lose those stations.
VHf High isnt so bad as long as you have the right antenna.
Channel 2 antenna tweak experiment
In anticipation of WFMZ's 69.3 (H&I) and 69.4 (Retro) moving to RF channel 2 (which I've never been able to receive at all), today I added two 17-inch "wings" to my 66-inch channel 6 folded dipole to see what would happen. As anticipated, this slightly reduced the signal from channel 6 (it went from 89-92 on my Sony TV's arbitrary signal strength scale down to 87-89, still quite receivable), but also allowed me to pull in a remarkably stable channel 2 (which currently airs KJWP's 2.1 through 2.4) on all my TVs and DVRs. The signal shows up with a strength 70 on the same Sony TV.
I didn't bother extending the whole twinlead folded dipole, but rather just attached two single-conductor wires to the ends of the folded dipole and fiddled a bit with the angle they came off the ends to get the strongest signal.
So at least here in Lower Bucks County it's possible to receive the 9.36KW VHF LOW signal from Roxborough with a homebrew attic antenna. My attic is about 230 ft. above sea level and the only obstacle between me and Roxborough is a lot of trees. YMMV.
wow - that's dedication to OTA :)
Well, not so much dedication, just trying to make it so my techno-phobic wife will not have to deal with change; she watches old Star Trek episodes (all the many incarnations) on 69.3 whenever there's nothing new or interesting on the networks.
As for me, at age 70 neither I nor my parents ever spent a dime to receive TV any other way than OTA. My investment in equipment is modest: a DB-8 UHF antenna, homemade VHF antenna, old (really old) channel master preamp on the DB-8, Kitztech low noise amp being used as a distribution amp, a handful of splitters and a VHF/UHF combiner, and maybe 100' of RG-6 and a bit of RG-59 all neatly out of sight. On the receiving end a Sony LCD 40" XBR that's probably pushing 10 years old but still looking great, a couple smaller sets one of which is a CRT still using a DTV converter box, and two OTA DVRs (DTVPal and DVR+) which replaced an even older Sony DHG-HDD500 DVR. A couple of roofs (or is that "rooves"?) ago I had a rooftop antenna, but for the past 25 years my antennas have been in my attic. That may be dedication to you, but it's just normal to me.
Looking forward (well, not really) to ATSC 3.0 transition, converter boxes again, and continuing challanges as they can never leave well enough alone.
WUVP has filed an application to channel share on WPHL's signal.
- Trip
  • Like
Reactions: NoReDist
If this post is in the wrong forum, I apologize...tough to figure out where to put it.
Last night I picked up a 1byone 50 mile indoor HDTV antenna and installed it. Based on TVFool and the FCC maps, I expected to be able to pull in WPVI out of Philly fairly easily as it was in the green/yellow areas. TVFool link to my location - http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de6a40c6dc8e088
Unfortunately, all I could get were channels out of Allentown which are in the brown area. I tried several locations and directions, and the best I did was 11 channels and no WPVI. Does anyone know any tricks/tips I could try to pull in this channel?
I'm no expert, but here's my 2 cents.
If you've read anything in this thread, you'll see that channel 6 is very hard to receive under the best of circumstances. At least the antenna you got does not appear to be omnidirectional, so you may have a shot.
Get the antenna over to a window (or out the window, for purposes of experimentation, if you can), and point the face of the antenna towards the Roxborough antenna farm. Scan for channels. Rotate the antenna so the edge is pointing towards Roxborough and rescan. One direction will be much better than another.
[or just wait a few minutes and someone with more technical knowledge than I will tell you how these flat antennas work, but this way you can find out for yourself].
If you're lucky, 6 will show up. It will be weaker than most of the other channels (I believe 12 suffers the same fate).
You are not, as the ad suggests, going to be able to just plop it on the wall and get hundreds of channels. There is a reason I have a full-sized antenna in my attic. Actually, two reasons: 6 and 12. ;)
Michael
You are over 40 miles away from Roxborough and do not have line of sight. Your UHF-only antenna has no hope of receiving channel 6 which is in the Low VHF band. You need an antenna with dipole elements that you can extend to at least 55 inches overall and oriented perpendicular to the direction of the signal. At that distance even that might not work unless you can get it on your roof or attic.
Last night I picked up a 1byone 50 mile indoor HDTV antenna and installed it. Based on TVFool and the FCC maps, I expected to be able to pull in WPVI out of Philly fairly easily as it was in the green/yellow areas. TVFool link to my location - http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id=e6a40c6dc8e088
The antenna you purchased is made for strong signal areas (those in green on a TV Fool Report). It does have some VHF gain but not much.
A look at your TV Fool plot shows that the Philadelphia stations are not very strong. If you are looking for all of the major networks out of Philadelphia that antenna is not going to get them, though mounting it on the roof would help quite a bit.
Your stronger network stations actually come from Scranton (except ABC from Phila) and you could likely pick up all the major networks from Scranton with a proper roof (or maybe attic) antenna (ABC, CBS, FOX, NBC, PBS + subchannels). The Harrisburg stations are a bit weaker and the Philadelphia stations the weakest (with some of them falling into the 'never' category). You'd want something like an Antennas Direct DB-4e for UHF and a Stellar Labs VHF-HI Antenna. For a one antenna solution you could possibly go with a Wineguard HD7698P (the smaller HD7694P might work). There are a few other possibilities. Aim to 16 degrees on a compass for Scranton (126 degrees for Philadelphia (but you'd likely never see FOX)). [More detail could be added if you need it.] Best wishes.
PS: I'll add that your report is at 10 feet. It could possibly change greatly at 20 or 30 feet.
My recommendation was for Scranton, which does not have VHF-LO. For Philadelphia Channel 6 you could use a Winegard HD7000 or possibly an AntennaCraft AC9. But my thought was that if one is going to the trouble of putting up an antenna one should try to get as many of the network channels (and anything else) as possible.
Can anyone tell me the PSIP title of WPVI? I'm in NY, and quickly received a station on 6-1 entitled "ABC NETWORK". I'm assuming it's WPVI, I just want to confirm. WABC's PSIP title is "WABC-HD" for what it's worth. Thanks!
Thanks for checking, I wonder what signal was picked up then! Are there any directories of PSIP names I could reference?
The short channel name field is limited to 7 characters, so to have seen "ABC NETWORK" means you were probably looking at the extended channel name, which most TV sets do not display. I have data from January for WPVI which shows that it does not have an extended channel name. Alternatively, you may have received WLNE from Providence. Unfortunately, my data for WLNE is from 2012, so it very easily could have changed since then. https://www.rabbitears.info/screencaps/ri-pri/22591-0_0.htm
To confirm, what do you see on WASA-LD 24-1? If you see "WASA-HD", you're looking at the short channel name. If you see "ESTRELLA HD", you're looking at the extended channel name.
RabbitEars has lots of TSReader data that can show things like that.
- Trip
