Does anyone have this set?
I've had it since July and have noticed a few problems I was hoping to get some advice on.
1. slight vertical geometry problem at the bottom of the screen. This is mainly noticeable when watching 4:3 content. It is clear that the lines for the veritical side bars curve in at the very bottom of the set. I have no experience at all going into a service menu of a TV. Is this something that is easily fixed or am I better off having a pro do it?
2. This next problem only happens with SD content. I haven't noticed it all with anything that's in HD. It' s a little difficult to describe, but I'll give it a shot. Mainly visible towards the sides of the TV, there will be horizontal lines if the image is blurry/out of focus. The color of the lines is whatver color the object is, but slighly darker. For example, if a shot is zoomed in shot of an actor's face - the face is what the camera is fouces on and that looks fine, but in the background, which the camera has out of focus, if it's just a brown building or something, I can see those horizontal lines. It's really tough to explain - maybe I can try and take a picture of it.
3. Ghosting. I think that's the term for what I'm talking about. If there is a football player, for example, on the screen, I can see another faint outline of the player to the right of the real image. It's very faint, but it's there. It's not always noticeable, but if I look for it, it's there. Also, if the screen is really black, lighter images stay on the screen after the image has changed.
Does anyone know if these are things that I can remedy by changing some settings? Does anyone have this set that could post what their settings are? I'm fairly confident I have the main controls set well (contrast, brightness, etc.), but, like I said, I've never messes with the service menu. Is this advisable? Would anything in that menu even help with those issues? I know geometry can be adjusted, but does anyone know anything about issues #2 and 3.
Thank you.
Thank you.
