I just purchased the Philips 50PF9631D/79 (50")
I have two possible problems
1. When the volume is low there is a feint yet perceptable humm coming from the speakers. When you turn it to mute, it dissappears after 5 s or so. When Mute if turned off, you can hear the sound 'start up'.
Initially I thought this was a fault and had the plamsa replaced, but I notice it again in the replacement set
Is this normal?
2. I have just had a case , whilst watching, the TV would just turn off, for no reason, and then turn on again. The remote stopped working. I reset the remote by removing the batteries and all is well now, but surely that is not normal?
Any ideas?
pelooyen
Is this normal?
Any ideas?
pelooyen
