I'll replace my 963SA with another DVD player in my HT and use the Philips with a Sony Grand Wega with just the RGB scart inputs, no component
My 963SA is also European so it also has the Scart outputs but I've heard that they are not RGB (?) and so it will not give "component" like results. If that's true what kind of connection should I use for the best results? Stick to S-Video or (if it works) run component to TV and use some kind of a converter for RGB Scart?
