Philips defines different resolutions accepted from pc and other sources (same port)
645 Views 0 Replies 1 Participant Last post by  cowlman
As we all know many companies and also philips specifically hqave different
resolutions accepted for
pc format
and
video format , through the same hdmi port
i am interested in the 37pfl7603D for example full hd tv (1080p)
which has the following specs
Supported Display Resolution
Computer formats 640 x 480, 60, 72, 75, 85 Hz , 800 x 600, 60, 72, 75, 85 Hz , 1024 x 768, 60, 70, 75, 85 Hz , Via HDMI/DVI input,
Video formats 480i, 60 Hz , 480p, 60 Hz , 576i, 50 Hz , 576p, 50 Hz , 720p, 50, 60 Hz , 1080i, 50, 60 Hz , 1080p, 24 Hz, 25 Hz, 30 Hz , 1080p, 50 Hz, 60 Hz
How is it technically explained the resolution is divided in to 2 different categories , pc and video.
I thought that if the panel was (1920x1080) then it could support this resolution even if the signal is from a pc or an external bluer ray player for example.
Which is the explanation?? thanks for your help
is there a difference between a resolution form a pc or a resolution from any other source ?
are there two diferrent types of resolutions?????
See less See more
1 - 1 of 1 Posts
1 - 1 of 1 Posts
