Status
Not open for further replies.
3301 - 3320 of 4792 Posts
It's not perfect, but yeah, it's definitely the best ATSC-tunered HDD model you're gonna find right now. Pretty slim pickins'.
Supposedly, Polaroid has a model with TVGOS that's due out sometime in the future, but I don't expect too much there, being a Polaroid and all.
And how much longer will TVGOS be available with analog OTH TV going out soon?
TVGOS has been in the process of switching over to digital for awhile now. That's how the guide will work, I'd presume. Otherwise, why release it? I don't think even Polaroid is that stupid. Everyone else stopped making recorders with the analog-based TVGOS long ago.
Actually, I think they did specifically mention that is was the newer, digital-based service in the article I read. I just don't remember where I saw it. I think there was a link to it here on this forum somewhere, and that's how I found out about the unit.
The link was over on the Polo digital recorder thread. It looks like it will be an internet TV guide type feature since the machine will also act like a slingbox as well as able to D/L to an ipod. If it lives up to all its hype, it would be an excellent machine.
I received my 3757 yesterday from the Philips online store (January version). This morning I recorded a program for 2 hours and 10 minutes on SPP on the HDD. I then dubbed it on high to a DVD+RW which plays back on the 3757 and another DVD player.
I normally import the video from DVDs into Ulead MovieFactory but this RW caused it to hang. When I looked at the properties of the VIDEO_TS folder it said that it contained 6.69 GB
(yes, I know this is impossible). I transferred the VIDEO_TS folder to my computer it contains 6.69 GB. There are two sets of identical VOB files (VOB_01_1.VOB (.99 GB), VOB_01_2.VOB (.99 GB), VOB_01_3.VOB (.99 GB), VOB_01_4.VOB (354 MB), VOB_02_1.VOB (.99 GB), VOB_02_2.VOB (.99 GB), VOB_02_3.VOB (.99 GB) and VOB_02_4.VOB (354 MB). VOB_01_1.VOB is identical to VOB_02.1.VOB, etc.
I have two questions. Did I miss a step in the dubbing process that caused duplication of the files? Has anybody else been able to import video recorded on the 3575 into Ulead MovieFactory?
That actually looks normal, and isn't/shouldn't be the result of recording with the 3575. Looking at the file folders of a disc I made yesterday on the pc, the results are the same. Duplicate files just as you've listed.
lafla: I have seen this problem happen frequently. It's nothing to do with the 3575 specifically, but rather with the fact that there are two separate file systems on a DVD+VR, the ISO file system and the UDF file system. For some reason Windows can get into a mode where it sees both at the same time and merges them, causing every file to appear twice. Over time I've seen my system get into that mode, out of it, and into it again as I've installed, updated, and uninstalled various apps. There's so much junk in the DVD driver chain on my system (some of undoubtedly trying to hide intentionally) that I doubt I'll ever sort that out.
I read in the sticky that the 3575 will amplify the incoming signal if it's first in the COAX line, i.e., cable-in > 3575 > STB. I currently have the STB first in line, with a composite-in to the 3575, and component-out to the TV. When the 3575 is turned on, and selected as the source (E1), my SD picture quality is better than it is directly from the STB. My question is this: Am I experiencing the same "amplification" phenomenon as if the 3575 were first in line? If so, I'm wondering whether it's worth re-wiring my system, or rather just watching SD channels through the 3575 (turned on, of course)?
In other words, is the only advantage to the "first-in-line" approach that the 3575 doesn't need to be "on"?
No, it doesn't have to be 1st on the coax. The 1st on the coax is for all who can TUNE channels separately on the 3575 so they can record one channel and watch another.
However, one user has all-scrambled channels but placed his 3575 1st on the coax anyway, and wrote that he "got a new TV"... the amplified signal made his TV 20% better PQ. See this post for the details. Connections to the STB are the same wherever the 3575 is.
It's interesting that you note an "amplified" looking pic when connected only thru a line input. I thought it was only thru the coax passthru, but maybe it's also amplified thru the line inputs? That would be another "cool" feature of the 3575!
Another cool feature is rapid play, one button which gives slow or fast advance with sound. I can quickly see slowmo sports plays or speed through a show and retain sound. Does a good job since you can understand most all said but get through quickly.
Thanks... I looked at that post, and I would concur that my picture is also ~20% better when viewed through E1 with the box turned on. I had previously assumed that the box was upgrading the signal from 480i to 480p until I read about the amplification effect. Now I watch all SD channels through the 3575, and for HD I switch the "source" to STB.
Thanks for the info!
I'll add a link to your post for others with a STB who might benefit from a "free" signal boost.
I also like how they use the 1.3x rapid play.
I use this feature on my Sony DVD player a lot, unfortunately it only has 1.2x and then jumps to 1.4x. 1.2x is a little slow, and 1.4x is kinda fast. My Panny DVDR's have the 1.3x but require RAM discs, which I don't use. I think Philips got the speed "just right" on the 3575 and allow it on standard R/RW discs. Just one more + to this unit, IMO.
Nope. Wasn't that. I just looked at the thread, and you're referring to the recent posts about the "Polaroid Freescape", right?
I never even saw those posts, and this was a few weeks ago. Maybe I just came across it on the net when searching for some new news on TVGOS's future digital plans, 'cause I do that from time to time. I could swear that "TVGOS" was specifically mentioned, but it's possible that either I, or they could've been wrong.
This thread *may* have some info of interest?
Apology for reposting, but I just wanted to ensure people were aware of this and if they would like to see video file recognition via the USB port to request such from Philips...
--Thanks much from the scorched earth of Southeast Louisiana in the forgotten region *south* of NOLA...
Originally Posted by BurntPixlz /forum/post/12861355
NOTICE:
I've called and e-mailed Philips via their website asking them to please update the firmware for the DVDR-3575H/37 so you can view and play videos from devices plugged into the USB port.
The device is capable of reading the file structures on USB devices, but in my opinion THEY HAVE DISABLED it's ability to see videos on devices plugged into the USB port.
I told them I felt as if their customers would be very appreciative if they would unlock hiding video files on devices plugged in to the USB port and personally, I see no logical basis for them filtering out video files on the USB port.
If you would like to see them enable this if possible, **PLEASE** call Philips at 1-888-744-5477 AND submit the request via their website here:
http://www.feedback.philips.com/cons...ODUCT_SELECTED
Originally Posted by BurntPixlz /forum/post/12866605
The DVDR3575H/37 already reads the file system fine on PC-made DVD's and IT DOES see video files when viewing a DVD, but for some reason they have disabled even being able to see video files on devices hooked to the USB port, and, in my opinion, this is something they have intentionally disabled and I would surmise all they would have to do is remove the filter that hides the video files on USB connected devices and your videos would then play fine via the USB connection.
I could be wrong, but you make it sound as if it would require a major re-write of teh firmware to which I would strongly disagree with as I believe they actually went out of their way to embed code to block seeing video files on USB devices.
Originally Posted by BurntPixlz /forum/post/12867194
"Thank you for your email to Philips Consumer Lifestyle. We received your request to add video viewing capabilities to the USB port on this device through a firmware upgrade. We will forward your concern to our Management department. This will be taken in consideration to improve our service."
Call them and submit the request via their web form, maybe if enough people do it they will attempt to SATISY THEIR **CUSTOMERS**
Yes, Freescape. Looks interesting.
You're probably going to see them sold cheaper a lot of places now that a new model has been announced - the 3576.
(What the heck is wrong with this site lately? I keep getting blank pages everytime I click on them. If it's because it's too busy, I've never gotten that before - just the "server is too busy" notice.)
Status
